Struggling to find the right size hex key to relase the caliper and also the top bolt seems to be rounded off, any ideas to a solution so i can change my pads without visiting a garage thanks guys.
hex key size 8mm you'll get in any shop with car parts, if your bolt is rounded off you better use socket key if this won't work the only way is to use file to change size of bolt then you can use one size smaller key
Thanks for the reply i did try a 8mm and it seemed to big i will give it another go and the top bolt has been rounded off by the honda garage as the car has a full service history before i bought it.
If its the same caliper as the saloon then its a 7mm hex bolt, not a common size on hex key sets . But as Grzesiek said, you should be able to get one fairly easily.
