Hi All,
I need to replace the above, i'm looking for drilled & grooved brake discs along with decent pads which last long, anyone got any recommendations please.
Also my mechanic took the front arm off to replace the bearing yesterday, and the ABS wire is connected next to the bearing. My mechanic said that the ABS connector, which is plastic, could break when trying to pull out the old bearing and that i might need a new abs wire/connector. Any info on this please?
