gtv
HI folks, just noticed that around the fuel pump on my 2005 diesel there seems to be a lot of fuel, upon further investigation I can see it has run along the top of the rocker.
Now I put some tissue at a couple of points along the rocker to see if I can see where it was coming from and took her for a test drive.
after about 15miles I stopped and checked and the only tissue that was wet ( in fact it was soaked) was the bit around the joint of the high pressure pipe and injector no1.
Now is there a seal there? do you think its a new pipe or injector req'd or just a nip up? I have tried but it does seem tight.
Car runs fine with no problems or starting.
Thanks for any help you can give.
