Channel Hopper
1) Following on from this post,
http://typeaccord.co.uk/forum/topic/23664-lag-in-acceleration/?p=246275
2) having the car failing to start a second time this month after a short stop when hot, and
3)noticing that the f***ing fuel filter is directly above the exhaust (and rather hot under a dark blue bonnet with insulation), I decided to look into possible failings and fixes.
Other Accord owners in the past will, either by natural response or, under pressure to continue their journey, done the thing that springs to mind, crank the engine until the battery goes flat.
I'v been there/done that with the result I had to travel home/back with spare battery. By that time - only - one of us had cooled down.
So far I have the following to offer as positives
a) leaving until everything cools down for about an hour and she starts with no issue. (not always convenient)
b) opening the bonnet and doing a) and she starts after about 20 minutes with no issue, (more convenient than a),
a) and b) suggest latent heat under the bonnet has something to do with this
c)Depressing the manual bladder until hard makes no difference at all to the starting, but it does confirm there is liquid in the pipes.
d) opening the fuel cap results in an escape of pressurised air/fuel leaving the tank at atmospheric pressure.
She started immediately after depressurising, so I next time this happens I'll do the same. It might be the components had reached a low enough temperature that got me under way but I'm not so sure.
