I have an issue when trying to change gear the lever seems to baulk between changes and get a bit stuck between gears. I've had a look at the selector in the car under the boot and there seems to be a lot of play at the end of the shaft that comes out at right angles to the gear lever. Should there be some sort of Bush on the end of this shaft ta
