GAZB
I noticed the other day that my drivers rear wheel was binding on the brakes on my 04 Accord CTDI , I took the wheel off and the caliper and thought the piston had seized but luckily enough it wasn't , I found the problem to be the handbrake cable sticking , it would be okay when I was applying the handbrake but it would not release so for the time being I have to either not use the handbrake or if I do I release it manually by moving the handbrake caliper bracket with a spanner , Ive never relaced an handbrake cable before is there anything in the DIY that ive missed , would you replace it with a new cable or have a go first at cleaning it through with some WD40
