jjmartin349571
TA Friends
Hi Folks,
I bought my Accord over a year ago now, and the whole time I've had it the headlight washers haven't been functioning. It's one of those little problems you keep putting off as it doesn't really affect day to day driving, but I kind of feel it's time to tackle it lol.
So far I've previously tested the pump and plumbing - all fine. I read the washers only functioned with the headlights on, tried this but still no result. I then tried to follow the wiring back but as it ran in to a loom I couldn't check for damage. I also started stripping the steering column trim, but I'm not sure where the switch would be located... Presumably it's a contact in the stalks, but somehow must be wired into both the headlights and windscreen washer? Anyone got any ideas or had a similar problem?
I'm pretty certain I've checked the fuse too btw might have to go to the garage and check to be 100% lol
Josh
Josh
