NOTE:
•HFT system does not allow you to pair your phone if the vehicle is moving.
•For pairing, your phone must be in its Discovery mode.
•Up to six phones can be paired to the HFT system.
•The following procedure works for most phones. If you cannot pair your phone to the HFT system with this procedure, refer to your phone’s operating manual, or talk to your phone retailer.
1.During the pairing process, turn off any previously paired phones before pairing a new phone. With your phone on and the ignition switch in the ACCESSORY (I) or ON (II) position, press and release the Talk button. After the beep, say ‘‘Phone set up.’’ The HFT system response is ‘‘Phone set up options are status, pair, edit, delete, and list.’’
2.Press and release the Talk button. After the beep, say ‘‘Pair.’’ The HFT system response is ‘‘The pairing process requires operation of your mobile phone. For safety, only perform this function while the vehicle is stopped. State a four-digit code for pairing. Note this code. It will be requested by the phone.’’
3.Press and release the Talk button. After the beep, say the four-digit code you want to use. For example, say ‘‘1, 2, 3, 4.’’ The HFT system response is, ‘‘1, 2, 3, 4. Is this correct?’’
4.Press and release the Talk button. After the beep, say ‘‘Yes.’’ The HFT system response is ‘‘Searching for a Bluetooth phone. Make sure the phone you are trying to pair is in discovery mode.’’
NOTE: Steps 5 and 6 show a common way to get your phone into its Discovery mode. If these steps do not work on your phone, refer to the phone’s operating manual.
5.Follow the prompts on your phone to get it into its Search mode. The phone will search for the HFT system. When it comes up, select Hands-Free Telephone System from the list of options displayed on your phone.
6.When asked by the phone, enter the four-digit code from step 3 into your phone. The HFT system response is ‘‘A new phone has been found. What would you like to name this phone?’’
7.Press and release the Talk button. After the beep, say the name you want to use. For example, say ‘‘Eric’s phone.’’ The HFT system response is ‘‘Eric’s phone has been successfully paired. Returning to the main menu.’’
8.If you want to pair another phone, repeat steps 1 through 7.
One thing I did before pairing my phone was to delete and restore all settings on the HFT as there were still the names and numbers from the previous owner stored in it see Pepsters post #20 here http://typeaccord.co.uk/forum/topic/361-hft-problems/ on how to reset it.
