Honda Accord CL9 (2004, 2.4 Manual): Clutch Pedal Failure — Diagnosis and Replacement Guide
bockersjb
Chertsey
Accord 2.4 Exec
Quick summary:
If your CL9 develops a creaking clutch pedal, a very low bite point, difficult engagement of first or reverse, or cruise control that suddenly stops working, inspect the clutch pedal bracket before condemning the clutch or hydraulics. In my case, the pedal bracket had cracked and was flexing away from the floor.
Car: 2004 Honda Accord CL9, 2.4-litre petrol, manual, right-hand drive (UK). I am sharing what I learned in case it saves another owner time and unnecessary parts.
Safety: Work on level ground, secure the vehicle, keep the keys out of the ignition, and follow the workshop manual for your exact model. If you are unsure about pedal adjustment, hydraulic components, fastener condition, or welding, use a qualified mechanic. Confirm that the clutch and both pedal switches operate correctly before driving.
Symptoms and Background​
From my first week with the car in 2016, the gear change felt notchy rather than typically “Honda-smooth”. There was no crunching and the gearbox worked, but lubricating the external linkages made no difference.
About five years later, the clutch began to creak as the pedal was released, especially slowly and during hot weather. Spraying lubricant around the pedal area silenced it temporarily, but the noise always returned after a few weeks or months.
Because the symptom came and went, it was easy to ignore.
By 2026, engagement had become noticeably worse, particularly in first and reverse. The bite point was only a few millimetres from the floor, even with the pedal fully depressed.
During a particularly hot spell, selecting first or reverse became very difficult. I sometimes had to select a gear before starting the engine, then start it with the clutch pedal held firmly down. On cooler days it improved, but in extreme heat the car was effectively undriveable.
Around the same time, cruise control stopped engaging. That initially seemed unrelated, but pedal movement can affect the clutch switches used by the cruise-control system.
Forum searches suggested several possible causes, so I worked through the obvious checks before ordering parts.
Possible causes considered​
  • Worn clutch ***embly — less likely because there was no clutch slip, even under hard acceleration.
  • Clutch release bearing.
  • Leaking or failing slave cylinder.
  • Leaking or failing master cylinder.
  • Low fluid level or a damaged hydraulic line.
  • Cracked clutch pedal bracket or pedal ***embly.
Diagnosis​
Under the bonnet​
I checked the clutch-fluid reservoir. The level was correct, although the fluid was dirty and due for replacement.
The slave cylinder showed no obvious leaks and moved when the pedal was pressed.
I also found no visible fluid leaks or damage to the hydraulic lines.
Inside the car​
In the driver’s footwell, I checked the master cylinder for leaks, the pedal pivot points, and the clevis/pin connection between the master-cylinder pushrod and pedal arm. Everything appeared intact at rest.
With someone operating the clutch, I saw the left side of the pedal bracket—nearest the centre console—lift away from the floor. The farther the pedal travelled, the more the bracket flexed, revealing the crack.
Diagnosis: the clutch pedal bracket had failed at its usual weak point. The bracket movement reduced effective master-cylinder travel, explaining the poor disengagement and likely the cruise-control issue.
Repair Options​
Replace, repair or reinforce the pedal ***embly​
Tools used​
  • 12 mm socket, ratchet and ***orted extension bars; a wobble extension is especially useful.
  • Long-nose pliers for the clevis-pin retaining clip.
  • PZ2 cross-head screwdriver.
  • Torch, ideally with an adjustable magnetic base.
  • Small container or magnetic tray for the fixings.
Parts and options​
  • Replacement clutch pedal ***embly. Honda UK did not have one available when I checked.
  • Import an upgraded Type R pedal from Japan; expect higher cost and a delivery wait.
  • Reported pedal ***embly part numbers: 46910-SDA-A01 for left-hand-drive cars and 46910-SEA-E41 for right-hand-drive/UK cars. Verify against your VIN before ordering.
  • Source a sound used ***embly from a breaker and inspect it carefully for cracking.
  • Have the original bracket professionally welded and checked for alignment.
  • Fit a suitable reinforcement brace, such as a brace marketed for the 2003–2007 Honda Accord/2004–2008 Acura TSX; confirm compatibility with your exact car.
While access is open: consider whether the clutch master cylinder and fluid also need attention. Replacing the master cylinder is much easier with the pedal ***embly removed, but opening the hydraulic system requires correct bleeding afterwards.
Removal​
1. Make room. Removing the driver’s seat is optional, but the extra space helps. If you remove it, follow the workshop manual and observe all electrical and safety precautions.
2. Remove the lower dash trim. On my car, there was one screw low down near the door, ahead of the OBD socket; the remaining panel fixings were clips. Work carefully to avoid breaking them.
3. Remove the side trim. Remove the plastic panel beside the clutch footrest; mine used a screw-type trim clip.
Pedal ***embly​
4. Disconnect the pedal switch. The ***embly is secured by two nuts and one bolt, all 12 mm on my car. Removing and unplugging the long cylindrical clutch-pedal switch gives much better access. Mark its position or measure the exposed thread before removal so it can be returned to the same setting.
5. Get comfortable. Expect to work on your back at an awkward angle in the footwell. Good lighting and a padded mat help.
6. Disconnect the master-cylinder pushrod. Use long-nose pliers to remove the small clip from the left side of the clevis pin, then slide the pin out to the right. Note the orientation of the U-shaped clevis before separating it from the pedal.
7. Remove the upper bolt. This is the easiest mounting, especially with the pedal switch out of the way. Keep the bolt and captive washer safe.
8. Remove the lower-right nut. A socket extension makes this straightforward.
9. Remove the difficult left-hand nut. This fixing is barely visible and has very limited hand clearance.
Because my bracket had already fractured on this side, I could move the pedal ***embly slightly towards the door and gain just enough access for a socket. A wobble extension worked well.
The two nuts fit the captive studs on the clutch master cylinder. Support the cylinder so it is not strained once the nuts are removed.
10. Remove the ***embly. With all fixings and the clevis disconnected, the complete pedal ***embly can be worked out of the footwell with a little manoeuvring.
Refitting​
1. Offer up the pedal ***embly. Align it with the two master-cylinder studs while positioning the master-cylinder clevis over the pedal arm.
An ***istant can hold the master cylinder firmly against the bulkhead from the engine bay while you line everything up. Avoid levering against or damaging nearby components.
2. Start the upper bolt. Thread it in first, but leave it slightly loose so the ***embly can still move for alignment.
3. Start the lower-right nut. Fit it loosely.
4. Start the difficult left-hand nut. Small hands are a major advantage here. Keeping pressure on the master cylinder from the engine bay helps expose enough thread to start the nut by hand.
5. Tighten the mountings. Once all three fixings are correctly started and the bracket sits squarely, tighten them evenly to the specification in the workshop manual.
6. Reconnect the pushrod. Align the clevis with the pedal hole, insert the pin in its original orientation, and refit the retaining clip securely.
7. Refit and check. Reinstall the clutch-pedal switch in its marked position, reconnect it, and refit the trim. Before driving, confirm smooth full pedal travel, a secure clevis clip, correct clutch disengagement and engagement, normal starting interlock operation, and proper cruise-control cancellation. If the hydraulic circuit was opened, bleed it correctly and check for leaks.
Key Takeaways​
  • A creaking pedal plus poor first/reverse engagement does not automatically mean the clutch itself has failed.
  • Watch the pedal bracket while someone presses the pedal; any movement relative to the bulkhead/floor is a strong warning sign.
  • Removing the driver’s seat is optional, but the extra room is valuable.
  • Have an ***istant available, ideally someone who can reach the awkward left-hand nut.
  • Consider the clutch master cylinder and fluid while access is open.
  • Verify replacement part numbers against the VIN, especially for left-hand-drive versus right-hand-drive cars.
