Honda Accord mk 8 type s idtec rear wheel bearing
SparkyTypeS
Mk8 honda accord
Could someone please help me I've taken off the old rear wheel bearing as it's knackered to find that the new one I've bought is slightly smaller in diameter so the mounting holes to secure it don't align correctly, apparently there's 2 versions of this rear hub/wheel bearing where one is slightly larger however I can't seem to find it anywhere any help would be much appreciated.
Did mine a while ago and the first two I got off ebay were wrong even though the part number matched and it said it would fit my vehicle.
I ended up getting one from Autodoc.
As you look down on it where the 4 bolts go in does it have a bump on two sides between the bolt holes?
Yeah mate and the new one supplied doesn't have them thanks ever so much for the reply
This is the one I ended up getting:
Hi , i have a similar problem coming as one rear wheel bearing is moaning just a little. My Honda is the same as yours with 80000 miles on a 2014 plate. Honda are wanting £212 Part no. 42200-TLO-G51 each. No problems fitting then ?
No problem fitting but keep the old bearing around in case it's the other side at fault as it was on mine.
Thanks for your reply, will replace both when the time comes to do the job. It is such a saving going to Autodoc for the bearings.
