Jay79
Had my lower kit fitted at the weekend on my type s tourer but it sits slightly lower on the driving side anybody else ever had this problem?
When you say genuine Honda do you mean A spec if so as Fahad said it will take a wile to bed in and settle.Once bedded in you may it drop slightly more.Ive done around 150 miles in it. Its a genuine honda kit. Shocks ans springs
Jay, they need to load the weight of the car on the bushes before tightening up the bolts..
How much of a ride height difference are we talking about?
Jay
Maybe you need to give it a run in and then get one of our experts CJ To have a look at it for you.
HMMMMMMMMMM We are having a Meeting at the Old Post Office off junction 38 M1 on Sunday this weekend a good chance to do all.
Check the meet section.
Yes the a-spec kit. I work at honda and one of the tech's did it for me.
By jacking up the car to load suspension you will never get the weight properly balanced. The struts should be loaded in their compression stroke to ensure correct loading . By jacking it up you are effectively loading the car in rebound stroke .
loading the suspension downwards will solve your issue. Get four big fellas in the car get it on the ramp and then nip all the bolts up.
Lastly to ensure this has had the desired effect from the centre of the hub to the wheel arch measure the distance both sides should be equal.
MOT Bay lift ideal for the job bud but get four guys into the car before you do that fella.
