Drivers side is a little tight, remove the filler neck of the washer bottle, this allows room, both head and dip are the same bulb H1 55 watt. remove the cover and then remove the pull off cable, you can feel for a spring wire "holds the bulb in place" the trick is to push this forward Towards you and move to the right, it will clear the bulb holder and the the bulb can be removed. Take care when fitting new one do not touch the glass of the bulb, it will only fit one way into the holder, replace the spring swing it to the left and then push in. replace cable and cover, then the washer bottle top. Same for both bulbs, although the main beam is tighter. I am ***uming that you have standard lighting not HID.
