As ***le says i get a loud huming noise coming from the front of the car only at 70mph (cant quite pin point which side) it is more audible decelerating at bang on 70mph, my first thoughts could be wheel bearing as the wheel shakes a bit too
im on 102k atm and no this is a new noise recently since travelling on the motorway.
nobody think its the wheel bearings? might be driveshafts also as iv had the symtoms of wheel shaking at 55 when accelerating and shakes go just after 60 then humming starts at 70. With regards to wheel balancing, idiots at a garage put hammer on wheel wweights for steelies on my alloys!!!!, i didnt realise until i got home as i was in a bit of a rush, idiots!
yep agree with Dan iron out the low cost things first.if it was me i would have the wheels of to see if there was anything trapped in the disk sheild.
then check condition of tyres then check all brakes are ok.
if that fells get the balance and tracking tested 1st
yes i had two front part worns thrown on recently (about 1000 miles ago) but only recently, the huming noise has appeared. I only got part worns as nobody had 205's in locally and needed them asap
Then its your tyres I would say, especially if they're budgets. The compound has probably just worn down now and showing the issue. try switching the front wheels to the back and if the noise moves with them wheels.. you know what the cause is.
OK, just bought 4 new tyres and will get them fitted and ask them to balance and swap alloys and see what happens, i wanted new tyres anyway as cant stand mis-matched tyres with crap part worns, i will update as soon as all is complete wish me luck!
Had new tyres put on all round (hugley quieter), balanced and 4 wheel aligned and swapped fronts with rears and im happy to say huming has gone! shaking has dramatically reduced to only a slight shake at 60 but sadly now clutch has started to slip!
Thanks for all help il give HH a ring after my holiday, £615 i believe now?
Good news Jon about the new tyres but sorry to hear about the clutch slip.
To be honest mate its one of these things with these cars but don't let it put you off.
Its a shame its not under extended warranty but most problems are so enjoy your quiet car
possibly, it is a light shake, nothing to what it was like before i changed tyre and swapped them with rears, sods law one thing after another, just hoping with clutch done (hopefully dmf will be fine) i will have trouble free motoring for a while and a remap
Im not sure mate, it was an Arnold Clark company car whilst in there hands for most of its life then some guy bought it then me. No reciepts came with it, just serviced at the right intervals, the only indication of a possible clutch change is the cruise control doesnt work? when i get it done i will let everyone know.
