Hi guys, I have a honda stream 04 rn3 with k20a similar engine with accord/civic, this evening with my torch, I saw a unsual liquid sitting on top of the gearbox, and I check further,and it was green colour type of liquid, and I check the coolant reseriour and inside was empty! I check from the top of the gearbox, coolant has slowly run to the bottom of it. I laid underneath the car trying to see further, but I couldn't found anything in particular, where could have cause the coolant leak from around the gearbox? It seems from the top to the bottom as I see large amount of fluid sitting on top of gearbox. Please give some advice..I quickly top it up to the correct level, not much only about 1/3 of the 1lt bottle and while the engine runing, I could see the coolant in the reseriour is moving like it had air inside..:-(
