Discovered this by accident when my finger slipped off the indicator stalk.
Not sure if this is in the manual or not as my car did not have one when I bought it but...
You can set the indicators into flash 3 times mode by doing the following
use stalk to flash indicator once then let go (I only tried this on the right indicator)
quickly repeat the above once more in the same direction as above
you can now use the indicators in flash 3 times mode
The car seems to lose this setting once you stop the engine.
