And there's loads to talk about tbh but I'll pick out a few things here for now.
For a kick off, I got this last Monday and noticed yesterday that there was a leak near one of the rear wheels. Took it into my local and they discovered one of the brake pipes was corroded to hell, leaking and in danger of bursting all together. Been told not to use it until Monday when I take it in to be fixed. Now there was signs of brake fluid spillage around the bottle which suggest to me the previous owner had been topping the fluid up and most likely knew this car had a dangerous fault. Very naughty that is, I could have had a serious accident on my way home with it. The other brake pipe is not great either so I'm getting both done.
Anyway two questions, firstly the cars not exactly snail pace slow but for a 2.0 it's still a bit disappointing really. I'd of thought it would have more go than this. What do other 2.0 owners think of theirs?
Secondly it's got this curious thing where in the car I can hear very clearly what I can best describe as an engine pulley wobble noise. Yet under the bonnet the engine sounds ok. There is a slight noise there but not as bad as when you're sat inside it. It's as though the engine makes its noise and it's somehow amplified through the bulkhead or the heater ducts maybe, making it much more audible inside the car.
I know it's engine noise as it does this when stationery as well as moving. Plus it's not a grinding or screeching sound so I don't think it's the gearbox. Has anyone else had a similar problem with theirs?
Finally what's the cambelt intervals on these cars? I can't find evidence of it being changed but at 87,000 if it was due at say 60, you would have thought it would have snapped by now if it's not been done.
Thank you,
Alan.
Thank you,
Alan.
