Led link
impne
Cold North East
Tourer type s
Does anyone have a link to correct led bulbs I need for tourer boot
Std bulbs are rubbish
Lee if its the same as the sallon its a 501 same as side lights and door cards
Cheers Brett
Just ordered some :)
What ones did you get Lee?
I had LEDs in my rear tail and brake lights but went back to standard lamps.
This was because they made the rear camera pic very crackerly
You need bright ones for the tourer boot, with as many LEDs as you can get. I got some 4xLED ones and they weren't bright enough for the boot. So I kept the originals for now.
Check out my LED thread
http://typeaccord.co.uk/forum/topic/14050-anyone-done-an-8th-gen-interior-led-swap/page__p__155827__fromsearch__1#entry155827
Rear number plate ones were these tyeop with 4 LED's (***uming it is number plate ones you are after, and not reversing light?)
http://www.ebay.co.uk/itm/2x-T10-501-W5W-4-SMD-LED-194-168-Car-Side-Light-Wedge-Lamp-Bulb-DC-12V-White-/310708963874?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4857b28a22
Sorry my fault
I meant inside boot lighting :) oops
Interesting link anyway may look into that
I've put two bulbs I had left over from my 7th gen side lights, they seem to fit and work ok
No worries,
I put the same LED inside the boot (but blue ones) but TBH they are pretty ***** as they are directional and the holder does not point out into the car.
I will get round to buying some blue LED's that are barrel shaped some time but in the meantime the standard bulb, but a 'white' version should be a lot better.
Still not that bright but a bit better :)
