Hi Guys and Gals,
I know this question was asked before but I didn't see a definite answer. I think I may need a new lower ball joint (obviously at the front). On Lings, the balljoint is not separate from the stub for some reason. The ball joint would have been fabricated separate to the cast stub for sure so I also expect that it can be removed.
Has anyone here replaced a front lower balljoint without replacing the whole stub? If so, where did you get the ball joint and what was the part number?
JM
JM
