CJM
Dr. Diesel
Symptoms have been a hefty smoke on flooring the pedal ( though its been remapped ) and the engine check light popping up every now and then. But last week I had a few episodes of stalling when coming off the motorway plus irratic idling.
Today I stripped and cleaned the MAF ( in its casing as I don't have 5-point torx bits ), then took off the IMRC valve. Wow..it was crud city :-
Its since had a spin and seems to drive okay. Time will tell whether the engine check light pops up again...
Nice job Ian,
Who did the re-map ?
Did you clean up the MAP sensor?
To clean the MAF you really need to take it out,
Was the butterfly valve a little bit sticky, that could restrict movement?
