Scott if you mean your normal driving beam and not high beam its H1
I also think high beam is also H1 as well just like the 7th gen
Im sure there H1 but just take one out as there easy not like the dipped beam.It will say on the body of the lamp what type they are just to make sure.It's the High beam mate! Ive xenons or HID's on the dipped!
Scott
Plug and play I would say.
TBO there is not much point doing your high beam as you very rarely use the.
Adam yes the H1 for the 8th gen are just plug and play the same as the 7th gen.i ment my head lamp bulbs was goin to order some of ebay but didnt want to waste my money if they didnt work
also of topic what grill do you have brett ?
Easy then Adam have a look at James DIYok thanks for the info i really like the grill you have i also like the GT tourer grill which is gold chrome as for takin the bumper of i did mine after only 3 days of havin the car really easy to do i did it whilst it was raining lol
These are the ones o brought for my 7th gen but there are hundreds to choose from.cheers for that do you no what ebay seller he used as goin to order some today
There fine mate our lights are not cambus
Nice one Adam did you take the lights out to get to the bulbs.fitted my hids yesterday cant belive how easy they are to fit id say about 2 hours to do them
Great as i need to take my bumper off to fit my new cold air intake duct.So this will good practise for meyou would be suprised how easy it is clips across the top a screw on each side of wheel arch and more clips across the bottom put a cover on the floor saves markin your bumper and then pull on the sides near the wheel arch till it pops out unplug fogs and parkin sensors if fitted.head lights have 4 bolts each. 2 on top 1 on side and 1 on front unplug all the plugs think about 5 then fit hids then build it back up
Nice one mate just need to wait for my bits to turn up now.I might even get some HID'S as wellyer man do it really easy only tools needed are phillips screwdriver and flat blade screwdriver maybe a trim tool i didnt i used a big flat blade screwdriver
Very easy mate nothing like the normal beam a 5 min job.
Even easer Scote it's near the main beam bulb in the same part of the light cluster.
