Skogshuggare
Hi all, I'm having some trouble adjusting my offside headlight. The beam is currently point too far down. Naturally I lifted the bonnet to manually adjust and can clearly see how to do so by using a Phillips screw driver to adjust beam up or down. I can feel some movement when turning the gear with the the screwdriver but the headlight position will not adjust either up or down...I even tried doing it in the dark 10 feet from a wall to check if the position had changed.
Just FYI my levelling motor is in the normal position and does not change headlight position when moved.
Any help appreciated.
