moisture in the boot
SirMacca
Widnes
`99 Accord Type R
Hi guys
Few queries
I've got an ATR with a couple of problems, one of them being water in the boot. I've never really used the boot having not needed to. I threw my neck warmer in there the other day after work and when I came to get it out I noticed it was actually soaking, then noticed the bootlid was dripping and covered in condensation all over it. I've always had a problem with the windscreen and rear window being misted up but put it down to the weather now I'm wondering if that has anything to do with it.
Any advice on how to fix the problem would be appreciated.
I'm also seeing this, the CD changer has now packed in (located on the boot floor, behind the N/S tail light, put my hand down the side and it is soaking. Seems to have rotted the connector on the CD changer too. Anyone know where I can source one of those? The changer still worked until the other day.
I've stuffed a load of rags down the side of it to soak the water up, until I can get it out and have a look.
