theballboy
Finally got the clutch put into the car. Originally started slipping around march with a remap and was fine after unistalled but knew it was only matter of time. Got a new orig Honda clutch for £200 and had Honda Chief mechanic install for me on his own time for £180 . Bargain me thinks. However he did say that there was quite alot of movement in the flywheel when he checked. Most people do them both at the same time.
Thing is I was under impression that the clutch was the main issue in these and not the flywheel. Now I'm freakjn out in case that goes within the next year. Will that mean a new clutch again?
Also difficult to change gear at times now without almost depressing the clutch pedal through the footwell. Does it take time just to bed in or will this always be the case . should I take it back to mechanic?
