Roy W
Anyone here use these suction or 12v pumps for changing the oil?
Are they any good on the Accord? See them advertised around the £20 -40 mark.
:lol: I remember that thread.
I use a "SEALY" vacuum pump, it works well, one thing to remember is that the oil filter holds a fair bit up there, so before you stop pumping or draining for that matter undo the filter housing to release the vacuum you will then get another 1/2 litre out.
:lol: :lol: :lol:I wish........ I can just about get a stain in the bottom of the container. I obviously need to be pumping a bit more furiously
What container? get the engine hot, remove dipstick, place extractor tube into hole push down, it will not melt. six pumps to create vacuum and watch it flow. Keep vacuum up by pumping, until you hear it slurping, leave the tube in the dipstick tube, remove filter top and the housing will drain down, pump a little more vacuum, jobs a good un. If you are using an electric pump, throw it in the skip and get a sealy or pela vac pump.I wish........ I can just about get a stain in the bottom of the container. I obviously need to be pumping a bit more furiously
