Oil filter torque plus best place for oil and coolant
danCtdi
Nottingham
2008 Honda Accord Ex
Hi a,
Honda reckons the car just needs an oil change and coolant change as it had its major last year. Firstly what tool or specifically torque wrench to oil filter adapter do you use to tighten the oil filter to the specified torque and secondly can anyone give me a link to the best place to get fluids from for an 08 ctdi.
Dan
Thanks but whenever I click that link I get an error about not being able to find the page.
my bad. when you reach 10 posts you will be able to see it.
there are hidden sections that only become available when you reach a certain post count.
No problem strangely enough it just appeared, just had a good read over the lubetech stuff looks like what I need plus found the laser oil filter wrench tool I was after
Thanks again
Any chance one of the admins could send me the discount code for the lubetech 0w30 non dpf oil offer?
Daniel the torque setting for the oil filter should be on the black filter body.
Cheers I was after the type of adapter to use, as I saw the 52 nm reading on it when I had a look under the bonnet to see what I was letting myself in for. All the bits bar coolant are on there way now thanks to you guys.
Is it an absolute requirement to raise the front end to drop the oil I'm thinking of using some drive on ramps and then chocking the back.
Have a look at these threads, they should help you out.
The first one gives a link and details of where to get the filter wrench, or at least what you are looking for
Oil filter Wrench
This one is an excellent DIY of the oil change procedure, you may know what your doing, but it is a handy reference anyhow.
DIY diesel oil service
As for driving up on ramps and chocking the back, the only issue is can you actually drive it up on the ramps, the front end tends to be to low for the angle of many DIY ramps.
Hope they help
Thanks again I will have a good look through the threads just acquired the wrench adapter and oil filter, so just waiting for my 25 litre oil drum to arrive and its on........
You may have a point about the front an ramps though will probably use my trolley jack and some axle stands.
You'll probably find that it takes less time to get it up on stands than ramps !
Glad to see your all sorted now
