Oil leak help
marv_ek4
Edinburgh
Accord Sport 2002
Hi guys, having an issue with an oil leak at the moment, It appears to be coming from under the distributor area. I don't think its the rocker cover and was wondering if theres a cam seal or seal on the distributor that could be causing the leak? its running down the gearbox and making a mess :huh:
Any help or advice from folk who have had the same problem would be great.
there is little o ring on distributor... change it and, I believe,everything will be OK ;)
part number 5 in picture.
f20b6 engine manufacturer code 30110-PDA-E01.
You can change it buy taking out alternator (no need to disassemble it)
