So I get a minor shake (the car not the steering) when accelerating from stand still but quite a harsh one accelerating at 60 ish.
Found quite a lot of play on the inner joint and shaft on the splines. Not rotation more vertical. Changed the joint and the shake/play is exactly the same.
Can anyone confirm if there is meant to be any play in that joint at all. If there isn't I would have expected it to be at least reduced with a new joint. Going to change the other one as it's not reduced the shake.
Seems this could be a very expensive guessing game.
Edit: unlike the ***le there is no probing going on. :wacko:
