My missus's honda stream 04 had running fine since we purchased last year, and it got 83k on the clock, well, I've seem as part of the k series engine maintainance the valve clearance checking/adjustment need to curry out every 25000 miles, so I believe that the engine hasn't been doing this kind of things and I would like to treat her with a checking and adjusting if necessary. I have a honda generator and I've been doing similar valve clearance adjusting for it and as the result of searching how to adjust the k20 engine, and it's quite easy that I could do the adjustment. Also with the workshop manual to back up. But one question guys, I'm not really sure the adjustment in millimetre as I need know what millimetre that is need for Intake and exhaust valve
Here is the information I found from the workshop:
Intake: 0.18-0.22mm(0.007-0.009 in.)
Exhaust: 0.23-0.27mm(0.009-0.011 in.)
In my knowledge, I need a 0.20mm feeler gauge for intake valve and 0.25mm for the exhaust valve is that correct?
