Quick question! Does anyone know which models were fitted with the outside temperature display? My 1.8S doesn't seem to have it, nor does a 2.0SE I know of. When the sun shines on the display, I can make out Trip A, Trip B and Outside Temp written in the background. Is this just something that the high spec models have as my button only toggles between Trip A and Trip B.
Ah, that makes sense. It would have been good if all models had that feature, as they can be quite handy especially at this time of year! Thanks for the replies
My ES has got it also!
Im not convinced of their accuracy though, unless my sensor is dirty it reads about 3-4 degrees above what it actually is outside.
If temperature sensor shows wrong temperature you can adjust it(+/- 3 degrees from basic measurement). First You need a simple thermometer to know what exactly temperature is.
Let's say. Outside temp is -3 degrees. Car shows -1 degrees. You need: turn ignition on (you must see out temp in dash) and hold "mileage reset" (button on the right odometer) for 10 seconds. value will cycle from -3 to +3 in Screen. lets stop when it show -2 (release then) and finally thermometer will show -3 degrees.
And I have one question about temperature sensor. Originally it is located in front of radiator. So after standing still for few minutes temperature rise till +10 degrees. Does anybody relocated temperature sensor anywhere further from its original location? Where, if so?
You would be able to see it by pressing the button for the Tripmeter, John. Like my 'S' model, I don't think your SE will have it. Just 'Trip A' and 'Trip B', whereas these guys that own ES/SE Exec and Type V models have an 'Outside Temp' option displayed on theirs too.
my accord is 6th gen IES 99m with f20b6. numbers in sequence from -3 to +3 apears in the degrees section.
p.s.when adjusting there must be temperature shown in odometer screen
