accord player
My Accord disgraced itself this weekend and is currently being recovered on a flat bed. Appreciate your suggestions as to root cause or knowledge of known weak spots in the cooling system.
Temp gauge rises to 3/4 only when climbing a hill. It was running fine at motorway speeds with 4 passengers plus luggage prior to this.
Pressure is building in the rad and pumping coolant into the rad reserve tank. Res tank then overflows out the cap - plus about 1litre of coolant is now in the res tank, not the rad, exacerbating the problem.
RAC dont know if its head gasket (explains the pressure and extreme coolant temp) but the fans are pulling cool air through the rad even at idle, which would suggets a blocked rad? Certainly the rad is the steel orginal and has significant fin damage - but it was working fine last week with the same fin damage!(Why didnt Honda use aluminium rads - its not a vintage car!)
Other sources could be water pump impeller?
Its not the thermostat as you can feel the hose warm when it opens from cold start
I will be pretty upset if its the head gasket - its a honda with 50K miles on it! So much for unbustable cars....
