Swallow
Hi All, not been on here for a while as my CDTi Tourer (2007) has been behaving very well of late - until now...
Battery warning light on - have used testers to check battery and it appears that the alternator has packed in.
Battery is at 12.3v when engine off and much the same when engine on. This figure goes down if I put all lights on to around 11ishv
Battery is 6 months old premium quality
It looks like the belt change/ re-route has never been done on this car, which is at 115k
The alternator/engine noise is more whiney than before, so given the above, I think it is safe to say the alternator has had it.
OR - are there any other checks i can makes somewhere? Fuses? etc?
I am near Witney, Oxforshire. I should be able to source a replacement alternator easily enough, however fitting it is probably beyond my expertise....
Can anyone recommend a trusted honda specialist/expert that could do the alternator swap for me & preferably the revised belt too at the same time. Obviously a bad time of year for this to happen but I'm also in a real rush to get the car back on the road...
All the best, Tom
All the best, Tom
