MrNotEnglish
Hi guys, I have a problem with my cl9. Everything was fine until when parked, revs dropped down, engine stopped, check engine came up. Started engine again only on petrol, rev'd couple times, exactly the same has happened, started once again and switched on lpg, rev'd and again engine stopped after revs dropped. It's fine when driving and keeping revs above 700revs/min. I drove 10 miles, then parked and checked again- the same sympthoms, but after keeping revs with accelerate pedal they stay where they should, but as soon as I switch off AC engine stops after rev drop (happened on petrol and lpg). It was perfectly fine on petrol and lpg, and even now keeps the power on both. What it could be? MAF sensor or lambda sensor? Air filter replaced about 1500 miles ago, engine oil changed 100 miles ago, ecu remapped by littleboo about 12000 miles ago. I'm going to have valves adjusted next week and lpg check and adjustment done as well.
Because it happens on petrol and lpg I would say that's not lpg injectors or petrol injectors. Have had some problems with starting not far ago, had to turn little bit longer sometimes, but I blame valves clearance that needs doing.
Please help guys, I'm on holiday 1300 miles away and coming back home on 26th so need to sort it out asap!
