docjd
AA called to EML-said above code
previously it has had front honda o2 sensor replaced(different code then) £240 or so then from memory
This is ***ume means cat is impaired
Drives fine -genuine cat is over £800 -cars only worth about £600 its done 110 k only drive locally now as have another car for longer journeys(xc90)
Any one have suggestions-the non genuine cats seem to be warrantied for only 1 or 2 years and are obviously not going to last??
I also thought although the rear o2 sensor has not brought up a separate code its probably on its way out as well??-lings honda list this as £200!-i know from forums non honda o2 sensors will not do!
The Engine on this car still sounds as if its done 50K!
