Parking Distance Control Unit location
poxxxy
MK8 Accord 2.2 IDTEC
Hi guys...
Just trying to get to the bottom of my Parking sensor woes (haven't worked since I bought the car). I get error code B2633 front bus failure... I tried taking apart the switch and swapping the bulbs to no avail and appear to have made things worse in the process now the switch is very temperamental in its behavior :D. I was wondering if anyone actually knows where the control unit is located? I have scoured threads to no end and not came up with anything.
according to autodata its on the right side of the steering wheel, level with the bottom of the dash binicle. so i imagine you get to it either under the drivers side of the dash or if theres an inspection panel at the side of the dash
