John M.
Hello again Guys.
I purchased a '00 reg 1.8S man on Tues (two owner, 84k miles with service history), didn't really get to drive it, just a few miles on a motorway then dropped it off at mates for a full inspection. I wasn't too happy with what I reckoned was excessive front end float and steering that was too light. Anyway, I got a call today with the low down on what the car needs.
1. Full service - Air & fuel filters, Plugs, Pollen filter, Engine oil & filter, Brake fluid change, 2 x wiper blades. Brake pads and discs all good, h/brake good. Front pads will be due at the next service. No steering or suspension faults found. 2 x bulbs required.
2. Both front tyres required.
3. Timing belt due & both cam & crank oil seals leaking. Fitting complete kit including w/pump (along with fresh coolant) both shaft seals, balancer shaft belt & oil seal plus seal retaining bracket (a Honda retro fit part & small money too, wouldn't have known about this if I hadn't joined up here, so thank you club). Alt & Pas belts to be replaced also.
So, all in all not too bad & nothing unexpected. I'll need to attend to a few jobs myself.
1. There's water ingress into the boot (great fun & games with that no doubt!).
2. I've got to replace the missing n/s mirror glass.
3. Renew the remote battery,
4. Repair a very minor damage to the rear bumper.
5. Check & adjust tappets (just for my own peace of mind),
6. Clean out the EGR system,
7. Lub all hinges & locks,
8. Change the g/box oil,
9. Investigate a very minor bit of play in the gear lever - anybody got advice on this?
10. Consider regassing the air con.
Then:
Locate a leather st.wheel & g/knob
Fit new no.plates
Carry out major valet.
Fit new carpet mat set.
Ah, the joys of buying a 12 year old motor! :lol:
Well, I collected the car last Saturday week after it's service and have since done close on 800 miles (mixed driving with some rapid motorway blasts), it's driving very well too and I'm happy with the mpg, averaging 35. As you can see from my original post on the car I wasn't happy with the suspension or the steering but as there was no faults found while the service was being done and no faults recorded at it's NCT test (MoT) 2,000 miles prior, I've put these 'issues' down to characteristics of these Accords compared to the likes of the Mazda & Merc I was driving but, I still don't recall my 6th Gen back in 2001 being the same, possibly age has taken it's toll on this cars suspension in general. Overall the car does feel better since originally driving it, I reckon the two new tyres it got on the front made a worthwhile difference.
Anyway here's an updated detailed account of the work carried out for those interested.
Service: Eng. Oil & Filter, Air Filter, Pollen Filter, Plugs, BFC, Wiper Blades, Timing Belt, Balancer Belt, Tensioner & Pulleys, Crank Oil seal. Checked for OBD codes and a general inspection including a road test. Plus: 2 x Tyres & a n/s Mirror Glass.
I've attended to: Front side light bulb, Hazard Warning Light switch bulb, Remote battery and Injection cleaner (will be using it initially for the next 1,200 miles or so).
Next, the to do list. Some are very important (see items 1-3 ) including a full valet along with claying & polising the paint!
1. Fit Leather St.Wheel - ordered from eBay.
2. Fit Leather Gear Lever gaiter - eBay.
3. Fit plain black alloy JDM Gear Knob - eBay.
4. Cut & Code original new Honda Key - eBay.
5. Fit 'new' Remote case - eBay.
6. Change Fuel Filter.
7. Gearbox oil change.
8. Engine coolant change.
9. Clutch fluid change.
10. PAS fluid change.
11. Set Tappets. Rocker Cover gasket kit - eBay.
12. Strip & clean: ERG valve & Plate, Throttle Body & Air Valve. Fit new Injector seals - Honda for the gaskets and seals from an Fuel Injection specialist.
And them! :
Fit Oil pressure & temperature gauges & look into getting better stereo speakers.
That's it so far!!! :lol:
