**** pit headlight levelling adjustment switch
Mr CL7
Eltham/Gravesend
2.0 petrol CL7
I adjusted my light level switch this morning and only the driver side one is going up or down. The passenger side doesn't move? :( It didn't use to do this. What could it be?
Faz
Faz inspect the wiring and ensure the clip is plugged in properly at the headlamp end. Failing that check for power at the headlamp connections for power.
I'm ***uming its only got one fuse running both units but could be wrong
Will check bro thank you.
