Hey guys.
I own a 2005 I-CTDI Sport but I am having a seriously confusing issue with it..
I was wondering if anyone had any advice or?
My car has 90,000 miles on the clock and as far as I can tell was relatively well looked after previously. I bought the car and fitted new discs and pads all around, a new fuel filter and air filter all Hondas own. They are all definitely installed correctly. I changed the oil as well which I'm sure is the right one and checked and all is topped up. However... I had a problem with the engine management light going on and a loss of power...I took the car to a garage and had the codes read and it had 13!!! Fault codes. I was told that they think that's gotta be wrong so they reset it. And told me that they think its a surging battery causing the issue of multiple problems and to bring back if it happened again. I took it out a day later and the problem reoccurred pretty quick...
To sum up.. The car when I started was fine until I hit the turbo upon which the management light went on and the car now refuses to pass 2000 rpm in any gear. There was no smoke or bangs etc. however after about 10 mins the turbo can suddenly be heard spooling and It works fine. It does this if it hasn't been driven for around 2 hours or more. It's like it needs to warm... Anyway the light is still on and I'm lost as to what to do
Help would be appreciated guys
Thank you
Thank you
