Steering was not smooth and making sci-fi noises,  inspected ps fluid,  reservoir was below min level,  topped it up, past max,  after 1 day its dropped down to just under max. Suspect leak somewhere.  Any idea where I start. Please
			Jon_G said:Pretty easy to check the cooler for leakage by shining a torch through the grill under the numberplate.
Goodluckmonkey said:Is the high pressure hose still clean?
Mine went up near the cam cover, bit ran down the back of the block and all over the rack. All the oil was nowhere near the hole.
yes, the garage is doing a thorough job, the entire engine bay was cleaned top & bottom, its the cleanest its ever beenStuH said:Are you checking from the top as well as bottom? removing any engine covers?
Goodluckmonkey said:If it's going from the cooler pipe as Jon says, the front subframe crossmember between the radiator and the motor gets soaked.
I also had to trim the ends off the lines to the reservoir a while back too, they get slack and then it weeps fluid down the lines onto the inner wing and subframe.
