Power Steering Reservior & Hoses (i-CTDI)
rlees85
Daventry
7th Gen ICDTI
I've got an 18 year old Accord. Been an amazing car and would really hate to give it up. This year however has been challenging....
The last set of woes started with the power steering high pressure hose leaking badly. Its the part that Honda want like £600/700 for and there are plenty of knock-offs on eBay. I found a local place that reconditions these hoses so I used them - problem solved.
Since then, when going into corners sometimes theres a whirring noise of varying volume, sounds like the power steering pump. Almost impossible to reproduce standing still, pump sounds perfect. I ***umed air in the system so I tried loads of random ways of getting air out and then I realised its actually leaking quite badly from the reservior to the hoses as well.
The knock off reservior/hose sets on eBay look like petrol only (mines diesel).
Honda simply do not make those hoses anymore, at all.
Used parts are risky and normally have the same problems (since they are 20 years old now too, after all).
How are you guys coping with having vintage cars now? Has anyone else had any experience with this problem? At this point just knowing if its likely the reservior or hose thats failed would be handy.
The hydraulic maintenance industry is well established. If you have the two end bits, you can always have the hose and crimped ends replaced. A decent hose doctor will be able to come up with a solution even if the end parts are damaged, as these fittings aren't specific to the Accord or even the automotive world.
Whoever will have the last driving i-CTDI will be have a car full of custom parts. Re the reservoir, there are definitely other Hondas that use the same brake fluid reservoir (Honda will never tell you which, though). The entire vintage car world operates on custom parts, re-manufacturing, and making parts from other cars fit. It is only growing larger.
Sadly not a lot around here willing to work on cars or help fabricate things and whilst I don't mind doing some maintenance I can't be a mechanic as well as a fabricator. I'll set it sorted this time for sure with used parts (thanks for the pointer other cars use the same reservior) and maybe some custom hose.
Does feel like its getting harder to keep anything thats not brand new on the road these days, in the UK at least
I've replaced my high pressure ps hose with a £20 eBay hose and it has been brilliant, no problems whatsover, was a 20 minute job.
The whirring noise well try and replace the fluid first, make sure it's honda fluid and no thing else. You can use a turkey baster to remove the fluid and replace remove and replace, kind of like a refresh. It's most important you only use honda fluid on this.
Keep at it mate, these are small problems and all your hoses are on eBay. The engines are too good. Until something major goes I'll be doing my best to keep it on the road.
Cheers for the replies, do not envy the matrix leak at all. I've been fairly good with coolant changes and using Honda coolant to try and avoid that exact problem!
The power steering noise is coming and going. I did flush it twice with Honda fluid whilst messing around with this. I got used hoses and the leak near the reservior is all good!
No amount of bleeding is getting the noise permanently stopped though. I guess the disruption to the system has somehow pushed the pump over the edge. I'll live with it until it affects driving (steering feels 100% fine, just loud sometimes) and see about getting another pump when that happens.
I think I might have got to the bottom of this. The OEM power steering hose has what looks like a very pointless join between two rubber sections of hose. This "join" is under or around the big rubber bung that you shove into the mount on top of the engine.
I think this join is actually a suppressor and my aftermarket/custom hose does not have this - hence, noisy.
It might be the extension and adapter is required for RHD models.
It wouldn't explain the pointless join on the -ve cable under the battery platform though.
