Power tailgate problem
tunstall
Staffordshire
Honda Accord Tourer
Yesterday (August 23rd) a problem with the power tailgate developed on my 2005 Series 7 Accord Tourer and it won't unlock using the key fob. I've consulted the Accord Tourer Owner's Manual and it advises to access the tailgate latch through the removable flap and to push the release lever to the right. This I've done and it has unlocked the tailgate, but using the key fob to lock and unlock the tailgate locks it but doesn't unlock it again. The manual advises to "have the vehicle checked by a Honda dealer" - which probably means a very expensive outcome!
Does anyone have any advice or suggestions please?
Check for broken wires in the wiring loom where it runs through the hinge area. They’re known for breaking over time.
Thanks for the replies - nothing damp in the back recently, and I will check the wiring. By hinge area do you mean where wiring comes through to the tailgate? I will remove the rear panel in the tailgate (carefully) to investigate. I'm also wondering if it's something to do with the close button that sits in the closing handle (upper r/h on panel). I'll remove that too and check.
As it is I can at least open the tailgate from inside and am now used to crawling in through a rear door and pressing the small lever in the latch.
Apologies Channel Hopper but I missed your suggestion to disconnect the battery for almost an hour. What will that do - reset the locking mechanism?
Yes where the loom comes through and becomes stretched and stressed over time. I’ve seen this happen multiple times now on these especially as they get older.
An update on the tailgate issue. I tried your suggestion Channel Hopper and disconnected the battery as advised - no joy. Also, I came across the following on a website - fixya.com and I've quoted it as written - "With ignition on, open the tailgate using the catch inside, then turn off ignition and disconnect the battery for a minute. Reconnect the battery and turn on ignition and let warning lights go through their cycle. With ignition still on shut the tailgate and Hey Presto should be good as new."
I went through this procedure 3 times - for good measure - but again no joy. So, next is to remove the interior trim panel on the tailgate - very carefully as I don't want any broken plastic clips - and check for any broken wires. I've already removed the two securing plastic inserts plus made a start on removing the closing handle/button plastic section - and I'm being ultra cautious. There will be another update.
Any further suggestions are welcome - I'll give them a go.
Thanks.
Thanks.
With the tailgate upholtery removed, you could check the connecti ng block that goes to the 'boot' button on the right hand side.
I did have issues once when trying to shut the door on something that did not fit in the boot.
Do you have any indication on the dashboard (red light/tail gate in orange) ?
I had similar with my 2009 8th Gen. Check your passenger window is working and the passenger side mirror folds in (if you have folding mirrors). All three rely on the PCB in the passenger door where the window switches are. Cleaning up all the contacts on that board including the tracks from the window switches fixed my power tailgate fault.
Here I am again and thanks for all the advice. I've made a couple of attempts to remove the carpet like trim on the interior of the tailgate - without success. Do I need to remove plastic trim on the tailgate beforehand or can the trim actually be removed by itself? I'm being ultra cautious in removing anything as I don't want to cause any damage.
On another subject - the car's MOT is due in late October and I recently had the underside of the car checked out to identify any issues. I needed a couple of new front tyres, which have been renewed, plus new front brake pads plus front lower suspension arm bushings - all replaced. The o/s sill also has excessive corrosion which will be attended to this coming week. The car is nearly 20 years old and I'm hoping I can nurse it through the MOT as it's been a damn good car and I would certainly consider buying another one - IF I can find a suitable car in well-looked after condition.
Meanwhile I would welcome any tips / advice about removing the inner tailgate trim so that I can sort out the tailgate locking/unlocking problem and start to use the tailgate again. It's just occurred to me - will the tailgate not opening be an MOT fail???
Hi, I have a 2004 ctdi and have just fixed my boot for about the 4th time over 3 years. This may help.
The problem for me has always been the wiring loom which is located top left looking into the boot. You need to pull off a couple of bits of trim which is straight forward and the loom is located on/behind the left hand hinge if that makes sense, there's a black cover that unclips. There are a lot of wires all together so just pull them out gently and have a look if any are broken, I've had a few broken and I simply solder them back.
You need to disconnect negative battery terminal before, if it doesn't work after connecting the terminal again undo it again and give it 30 secs and reconnect. It always has worked again for me. You could check the fuses first.
In regards to the MOT I believe the boot needs to be opened so yes it needs to be working. One year I got lucky and the guy allowed me to open it from the inside so he could check the boot but another year a different tester got really funny and refused to test it. I would definitely get it fixed.
Hello Rob88 and thank you for your advice. I've just spent another fruitless hour trying to sort this problem out. My car is the Tourer SE estate (2005) and with you mentioning the "boot" I ***ume your CTDi is a saloon? This latest effort involved trying to remove the black plastic trim that covers each of the pivot points where the tailgate lifts. I took pics and tried to upload but told "the uploaded file is too large" so no joy there! However, from your description I ***ume there is wiring running inside the plastic trim. The MOT is due in late October so I have a few weeks to sort this out.
I've just spent nearly £1k dealing with various issues for the MOT - including welding of off-side sills, suspension bushings, new front tyres, and new front brake pads and I'm reluctant to spend much more on a car which is nearly 20 years old, but which has served me well for 9 years now.
Meanwhile, I'll try again to sort this out, and thanks again for your advice.
And another update on the tailgate problem. The Accord went to the MOT garage I use and with a new NSF upper suspension arm fitted the Tourer has an MOT for another 12 months. A couple of advisories but nothing serious.
Also, the mechanic managed to remove the tailgate trim which has revealed all the wiring and workings of the tailgate mechanism. The flimsy plastic tools I was using couldn't do the job but a long-handled tool that he had did.
I've been contacted by another member who has a tailgate latch motor - same part number as mine (74800-SED-9010-57) so this might be the best way to go.
Sorry have you got the tail gate working? Have you fully checked for broken wires?
I have the 2004 estate. Saloon may be slightly different. I have only ever fixed broken wires, changing motors etc I have no experience. When I took all of the trim off my boot Ill just say the workings of the tail gate looks mightily complicated and is beyond me. Many things on this car have impressed me with the engineering that has gone into it !
I still say it’s a broken wire, you haven’t checked thoroughly enough.
second this, can be hard to find but factory strain relief isn't always meant to last 20+ years, and tourer boot wiring is known to fail even on non power tailgates
2017 x-trail, doesn't look too bad but when you start digging you find stuff, would bet the honda isn't anywhere near this bad but look into where it flexes and where it ties down to the hinges and you're sure to find something
I've rarely, if ever used the motor lift system on my Tourer. I would however look closely at the alignment of the tailgate around the rear wing indicators, moreso if you have seen any warnings flash up - even momentarily - on the right of the dashboard.
As before, disconnect the battery overnight once checks have been carried out to reset everything.
Thank you all for your comments & advice. I have checked the wiring under the plastic cover on the near side hinged area (looking into the car with the tailgate lifted) and despite it all looking like coloured spaghetti I couldn't see any broken wires. I agree that with the tailgate cover off it appears to be a complicated affair and well beyond my understanding. I will look again at the hinged area wiring - carefully - to see if any wires are broken.
I've said before that the Tourer has been a damn good car since I bought it in October 2016 with 89,000 miles. However, since the MOT of last October I've spent over £1,500 - tyres, exhaust repairs, sills etc welding, front brake pads etc. etc. etc. - and while I have an MOT until October 2026, and have just paid £395 for 12 months road tax - I'm questioning whether to keep the car. However, every time I get in the car, put the keys in the ignition and drive I know why the Tourer means so much to me. Sentiment over reality?
I'm keeping the car for the time being and will continue to see if I can resolve the tailgate problem. Meanwhile - safe motoring to all!
I’m guessing it’s a 2.4 petrol variant
Hi - no it's not a typo and the Tourer is an Accord VTEC SE, 2.0 litre - petrol engine. The last V11 gave a cost of £395 for 12 months tax. Considering my partner pays £35.00 for her Honda Jazz - that's quite a difference - but bigger engine. I ***umed that £395.00 was the correct amount - is that MORE or less than others are paying?
I've had another look at the wiring and I cannot see any broken wires. Granted there are a lot of wires but I was really careful and tried to pull individual wires as carefully as possible. Maybe I've missed one lurking beneath another wire?
The fellow Type Accord member with the latch motor hasn't replied to my last message - so I don't know what's going on there.
As things stand I'm going to live with the tailgate problem until the New Year and then investigate again.
Strange that it is significantly higher than the I-ctdi diesel 2.3 litre.
How "significantly higher" is my road tax compared to yours? I would be interested to know what other Accord Tourer owners are paying.
Anyone - let me know what your car tax is - please.
Mine is £265 a year being classed at 157 g/km emissions.
I think yours is 200 g/km which is indeed £395.
I've had broken wires that weren't visible on the outside. The stretch had over time snapped the copper filaments inside but the insulation was intact. This wasn't on an Accord so IDK if the rear door harness wires are prone to this.
You can get fairly cheap puncture type probes (example) that fit on multimeters, which push a needle probe through wire insulation. Two of these can be used to check continuity across a flex zone. You need to strain the wire as you test, as in a relaxed state the wire might conduct OK. This may need more than 2 hands.
Do you have the service manual to check wire harness colours?
