Hi there
I have a 2004 2.4 Tourer Exec Auto. Love it to bits. Not had it long and getting to know her. I prefer older cars to newer stuff.
It has a pretty old Nav system as standard, premium sound setup. I don't like it much, quite fiddly to use on the move and it seems you have to have all the kit installed just to use the HVAC system. I thought I got hold of a non nav premium sound unit although after fitting seems the A/C compressor no longer engaged though everything else worked fine so I put the nav setup back in and the A/C compressor now kicks in again. I have a Grom USB3 for added audio inputs (would not recommend this company btw quite a shady outfit, well the UK part anyway, from my experience). Now I have one question and one issue after this swap attempt;
1. Is there any way to put the non nav premium unit in and get the A/C compressor to work? After trying what I did it seems the activation of the A/C compresosr is intergrated into the control unit somehow.
2. My outside temp now reads about 10deg C lower than what it should be. It was working fine before the swap attempt. It was about 10deg C outside but when I put everything back to normal the outside temp showed -1deg C almost like it has re-calibrated to 0. After driving for a bit it went to 0 so seems it is working but out of cal. Is there a whay to re-calibrate/initialise the outside air temp? I know of a way to make minor corrections but I believe that is only limited to a few deg +/- wheras mine seems to be out by 10deg.
