Shafanotwo
Mate I drive a 8th gen as a taxi & if a headlight goes mid shift forget it the bulbs are near on impossible to change without taking the bumper off!
II thought though on the Accord they used exactly the same headlight ***embly for the halogen bulbs and the Xenon bulbs as the mounting points for the Xenon ballast exists on the standard halogen headlight units. So what would be the difference in this case between retro fitting the Honda factory Xenons into the headlight and fitting after market HID's.
Couldn't you argue the car came fitted with factory Xenons and the ballast have since packed up and you have simply replaced them with an after market set?
So the question I would ask is if the lights are doing what they are supposed to do in all conditions why do you want to go to all the trouble of fitting HIDs which in the end could cost you a lot more MOT failure, fines, costs to replace after either of these two???
Or is it just because they look good when they are on ??? Which I would say how chavy is that.
Personally it's because I'm a modder at heart, and that means I want the best I can, regardless of what it may or may not add. Changing your wheels and suspension very often reduces the cars handling and road-holding, but people do it anyway, same with bodykits etc. I would never go for 6000K+ HIDs as I actually hate the blue look on headlights.
Nah HIDs were getting boring. If the Police have pulled him for them then they obviously have been informed about the MOT changes and were starting to enforce the law. Or maybe they just wanted to look at the beauty that is the Honda Accord.!!!Guys let stay on topic here.
If they are not self-leveling, with correct alignment (i.e. correct lenses) and headlight washers to boot - then they are not permitted, and will not be Euro test.Double check with who you bought them from to ensure they are Euro tested
