Quick TIP brake caliper
SIlverCloud
UK
2.2I-CTDI
Hey was changing brake discs in front and demaged bleeding valve it was very rusty and it snaped out ,so have to get another brake caliper.All brake fluid leaked out,I know how to bleed them but just wondering about brake caliper bolt with hole in it do i need to align that hole in a bolt with brake line or just tight it.
Any other tips since i have to bleed all system?
many thanks -_-
No need to align the hole because it aligns itself when you put the bolt in but you need 2 new washers on each side of the 'banjo' fitting on the brake line and tighten the bolt to the correct torque setting.
thanks
