Help please as realy fed up now, so after I bought my car I noticed a near side rear hot wheel. So I had a look and the caliper was rusty and sliders seezed up. So did a bit of work replacing the caliper and cleaned up sliders, also new pads fitted. Still the same a very hot wheel. So next I replaced the discs and cleaned up the hand brake bits and bobs as I was there. The old disc was scored badly so needed doing. So now I have a very hot set of new pads, discs and new caliper!!!! So now after sifting over many problems with rear discs on the 2.4, was next a new flexi hose from Honda!! So replaced that today, very easy realy and guess what?? Two very burnt fingers after I pulled over into a layby to see if it had worked!! Still the same!! HOT wheels, calipers ect.
Got back home and took the wheel off, took the caliper off and wheel spins just fine, and I can push the piston in with my hands. Please if anyong can help as getting skint and burnt lots now!!
Pete.
Pete.
