-Rich-
Ever since I bought the car nearly 3 years a go I've had nothing but trouble with them (this is the tourer) constantly binding and 6 months a go I replaced the calipers, slider pins and hoses. Everything has been fine until recently.
I keep getting a hot smell from the OSR, it's been there for a few weeks now. I stripped everything down yesterday and all the new parts seem fine. Brake pads aren't seized and move freely. I also smelt everything including the disc and the inside but couldn't find the same smell.
The hub does feel warm so I think the handbrake shoes could be rubbing again. I tried adjusting them before but got frustrated with so a garage did them for me.
I tried adjusting the shoes again but they're too loose now and the handbrake sits higher. After a drive I was still getting the smell so I'm abit stumped now. The cable is moving the shoes ok but one moves more than the other, is that right?
I'm starting to wonder if it is the brakes now but the only other thing is the bearing, which isn't making any noises or have any play.
Also anyone got tips on adjusting the handbrake shoes properly? If I adjust so the disc doesn't turn and then back off a few clicks I still get a rubbing noise when spinning it. If I adjust until the rubbing stops the handbrake goes too high and it doesn't hold as well.
