Hi guys, I took my car to a mechanic that I use (not anymore) to replace a broken rear drivers side and he was being lazy and tried to remove the light without removing the bumber. He broke the light fitting plate in the process and used it to fit the replacement light, even though I had given him a new plate with the fitting. He then had to remove the bumber which he only did half way. The light is now further in then it should be and the bumper near the light fitting is not clipping in correctly and is sticking out a bit. It looks like he may have damaged one of the clips perhaps.
Would getting another competent mechanic to fit the light fitting with the new and unbroken plate resolve this? Never going back to that mechanic. Lazy s**t
