Plumber
Hi,
My car has been lowered ( ruff guess 60 - 70mm
I have bought front and rear camber kits, front no probs all done.
But the rear I am having problems removing the lower rear and lower center link bolts on the chassi side,
I've used a whole can of wd40 and all my weight all be it not tht much and it still won't budge.
The center lower arm nut is seized solid,
the rear lower arm bolt is seized in the bush but the one side has a nut tht is welded to, a blate too stop it turning I'm guessing, is there any trick too getting it off if not,
does anyone know the bolt sizes too replace them so I can cut it out.
Help is very appreciated
Rich
Rich
