ckh
Anyone know what's needed to fit recaro's to a CL9?
apart from CL7 rails?
thanks
thanks
you will need genuine recaro rails with the CL fitment, the OEM rails do not detach from the seat i dont think and also do not fit Recaros. Also the OEM seats have airbags in them, Recaros do not, so your SRS light will come on and you will need to find a way to bypass this otherwise your airbags wont deploy in an accident (also i think is now an MOT failure?). I dont think its worth the effort and cost, probably better off just buying a DC2 lol. Or if you need the space, save up for a CL7 as that probably has in-built upgrades such as bracing from factory and has a K20 with a better VTEC range so is more of a 'sporty' drive to actually justify having Recaros!but either way it has been done as i remember someone welding stuff together to make a set of rails which fitted. It may be worth investigating whether FN2 seats are a direct fitment as this could be easier and also relatively sporty! let us know how you get on if you decide to go ahead
He has a point, the srs errorThe CL7 Recaro Seats are the same as the ATR. Fantastic and very comfy on long journeys but I always found the static seat height to be annoying. I would stick with the OEM seats in the CL9 and avoid the hassle of the SRS light issue due to the side airbags.
