Removal of A pillar and ceiling
AndyHK
United Kingdom
06 Accord Executive
Bought myself a windscreen recorder, and I want to hide the cable behind the ceiling and A pillar panels, but I couldn't found any info of that.Is there anybody knows how to?
Also, the curtain airbags are locating there, should I touch them?
On the a pillars there is a little plastic clip saying airbag IIRC. get a small flat blade screw driver and prize it away from the A pillar and the trim will become loose. Just easy it away from the A pillar and you can then easily run a wire up there
Dont remove the headlining, you should just be able to push the wire between the windshield and the headlining with a bit of small plastic.
Thats how i wired in my bluetooth in to my old 7th gen and i never had a wire visible.
Nope wont trigger the air bag. I removed mine many times when i fitted my hands free kit and also my laser / camera detector.
as Adam said, but still be careful as curtain air bag is behind it don't go poking it with a screwdriver :)
