Has anyone any experience of replacing the old sat nav unit with a multi media unit, the Bose unit is running ok but just may want a change if it's not too much work.
If the original sat nav unit is a double din, then you could get a replacement unit that's supplies with a cage, and it should go in easily. Might involve a little fabrication and finishing, but there will be quite a bit of wiring to do.
